Perform the following procedure to display the RSTP-related port level configuration details.
Display RSTP configuration information:
Switch:1>
show spanning-tree rstp port config 1/1
RSTP Port Configurations
Port Number : 1/1
Port Priority : 128 (0x80)
Port PathCost : 200000000
Port Protocol Migration : False
Port Admin Edge Status : False
Port Oper Edge Status : False
Port Admin P2P Status : Auto
Port Oper P2P Status : False
Port Oper Protocol Version : Rstp
Use the data in the following table to use optional parameters with the show spanning-tree rstp port config command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
