After you have configured the SPBM infrastructure, you can enable SPBM Layer 3 Virtual Services Network (VSN) to advertise IPv6 routes across the SPBM network from one VRF to another using the following procedure.
SPBM Layer 3 VSN uses IS-IS to exchange the routing information for each VRF.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select IPv6-VPN.
  3. Select the VPN tab.
  4. Select Insert.
  5. Select the ellipsis [...], and select a VRF.
  6. Select Ok.
  7. Select Insert.
  8. In IsidNumber, double-click the 0 value, and then enter the service instance identifier (I-SID) to assign to the IPv6-VPN.
  9. Select Apply.
  10. In Enable, select true or false.
  11. Select Apply.
  12. In the navigation pane, expand Configuration > VRF Context View.
  13. Select Set VRF Context View.
  14. Select the VRF tab.
  15. Select a context to view.
  16. Select Launch VRF Context view.
  17. In the navigation pane, expand Configuration > IPv6.
  18. Select IS-IS.
  19. Select the Redistribute tab.
  20. Select Insert.
  21. Configure the parameters as required.
  22. Select Insert.
  23. Select Apply.
