If the EDM user session remains unused for a duration of ten minutes, the system displays the following message:
Your session will expire in about 5 minute(s). Would you like to extend the session?
If you do not respond, EDM automatically ends the session with the following message: Your session has expired.
You can log on again if you want to continue to use EDM.
