View Trunks
Perform this procedure to view the MLT-based SMLT configuration.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select SMLT.
  3. Select the SMLT Info tab.
SMLT Info Field Descriptions
Use the data in the following table to use the SMLT Info tab.
Name
Description
Id
Shows the MLT ID for this SMLT Read-only.
MltType
Shows the MLT type of this trunk.
RunningType
Shows the SMLT running type.
