Graph Chassis Statistics
Create graphs of chassis statistics to generate a visual representation of your data.
  1. In the navigation pane, expand Configuration > Graph.
  2. Select Chassis.
  3. On the Graph Chassis tab, select the tab with the data you want to graph:
    • System
    • SNMP
    • IP
    • ICMP In
    • ICMP Out
    • TCP
    • UDP
    • Fabric Attach
  4. Select the statistic you want to graph.
  5. Select the graph type:
    • line chart
    • area chart
    • bar chart
    • pie chart
