Use this procedure to configure the device subject parameters to identify the device. The parameters include name, Email ID, company, department, and location of the subject.
- Select Certificate .
- Select the Global Subject tab.
- In CommonName, type the name of the subject.
- Complete the remaining optional configuration to customize the policy.
- Select Apply.
Subject Field Descriptions
Use the data in the following table to use the Subject tab.
Name |
Description |
CommonName |
Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority. |
EmailAddress |
Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority. |
OrganizationalUnit |
Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority. |
Organization |
Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority. |
Locality |
Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority. |
Province |
Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority. |
Country |
Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority. |
InstallFile |
Installs the specific certificate file type obtained offline from the Certificate Authority. |
InstallFileName |
Specifies the certificate file name to install. |
UninstallFile |
Uninstalls the specific certificate file type obtained offline from the Certificate Authority. |
UninstallFileName |
Specifies the certificate file name to uninstall. |
GenerateCsr |
Generates the certificate signing request to obtain the offline subject certificate. |
