Perform this procedure to define vendor options definitions.
![Note](images/note.png)
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Define the vendor options definitions for DHCP server:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-option-def 1 type string Switch:1(config)#ip dhcp-server vendor-option-def 2 type uint32 name firmware <cr>
The following table defines parameters for the ip dhcp-server vendor-option-def command.
Variable | Definition |
<1-255> |
Specifies the vendor option definition. |
type ipv4-address | uinit32 | string |
Specifies the vendor option definition data type as follows:
name WORD<0-128> |
Specifies a text label that identifies the vendor option definition. |
