The following table defines parameters for the ip spb-multicast-policy command.
Variable
Value
apply
Applies the IP SPB Multicast Policy on route-map.
enable
Enables the IP SPB Multicast Policy on route-map.
route-map WORD<0-64>
Specifies the route of the policy.
WORD<0-64> specifies the name of the policy.
vrf WORD<1-16>
Specifies the VRF name.
The following table defines parameters for the match command.
Variable
Value
multicast-groupWORD<0-259>
Specifies the multicast group for IP SPB Multicast Policy .
WORD<0-259> specifies the name of one or more prefix lists, separated by a comma.
The following table defines parameters for the set command.
Variable
Value
data-isid <1-15999999>
Specifies the data services instance identifier (I-SID) for static I-SID routed multicast policy.
rx-only
Specifies the received traffic only, applicable to static I-SID routed multicast policy.
tx-only
Specifies the transmitted traffic only, applicable to static I-SID routed multicast policy.
