Use the following procedure to clear entries (static or dynamic) from the DHCP Snooping binding table.
  1. Enter Privileged EXEC mode:
    enable
  2. Enter:
    clear ip dhcp-snooping binding [dynamic|static]
Switch:1>enable
Switch:1#clear ip dhcp-snooping binding static
The following table defines parameters for the clear ip dhcp-snooping binding command.
Variable
Value
static
Clears static entries from the DHCP Snooping binding table.
dynamic
Clears dynamic entries from the DHCP Snooping binding table.
