Use this procedure to view IP multicast route statistics.
You must enable the collection of multicast statistics.
- Select Multicast.
- Select the Stats tab to view the statistics.
Stats Field Definitions
Use the data in the following table to use the Stats tab.
Field |
Description |
GroupAddress |
Specifies the multicast group IP address for which to show statistics. |
SourceCounter |
Specifies the number of sources associated with the multicast route record. |
Pkts |
Specifies the number of packets received for the associated IP address. |
Bytes |
Specifies the number of bytes received for the associated IP address. |
AverageSizePerPkt |
Specifies the average packet length for the associated group IP address. This information indicates only the ingress packet length and is calculated using the following formula: ingress packet/ingress byte. |
