  • Enable the web server.
Configure the web management interface to change the user names and passwords for management access to the switch using a web browser.
HTTP, FTP, and TFTP server supports both IPv4 and IPv6 addresses, with no difference in functionality or configuration.
You can also use the CLI interface for creating users.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select General.
  3. Select the Web tab.
  4. Complete WebRWAUserName and WebRWAUserPassword to specify the user name and password for access to the web interface.
    This user will have full permission.
  5. To enable the RO user for the web server, select WebROEnable.
  6. Complete WebROUserName and WebROUserPassword to specify the user name and password for access to the web interface.
    This user will have read only permission.
  7. Select Apply.
Web Field Descriptions
Use the data in the following table to use the Web tab.
Name
Description
WebRWAUserName
Specifies the RWA user name. The default is admin.
WebRWAUserPassword
Specifies the password for the RWA user account. The default is password.
WebROEnable
Enables the web server read-only (RO) user, which is disabled by default.
WebEncryptionType
Specifies the ciphers for preset version of TLS for the web server.
WebCertSubjectName
Specifies the digital certificate subject Name used as identity certificate in the web server.
WebCertCAName
Specifies the digital certificate CA trustpoint name used for the certificate in the web server.
WebROUserName
Specifies the RO user name. The default is user.
WebROUserPassword
Specifies the password for the RO user account. The default is 12345678.
MinimumPasswordLength
Configures the minimum password length. By default, the minimum password length is 8 characters.
HttpPort
Specifies the HTTP port for web access. The default value is 80.
HttpsPort
Specifies the HTTPS port for web access. The default value is 443.
SecureOnly
Controls whether the secure-only option is enabled. The default is enabled.
InactivityTimeout
Specifies the idle time (in seconds) to wait before the EDM login session expires. The default value is 900 seconds (15 minutes).
TlsMinimumVersion
Configures the minimum version of the TLS protocol supported by the web-server. You can select from the following options:
  • tlsv10 – Configures the version to TLS 1.0.
  • tlsv11 – Configures the version to TLS 1.1.
  • tlsv12 – Configures the version to TLS 1.2
The default is tlsv12.
SSLRenegotiation
Specifies whether SSL renegotiation is enabled or disabled.
HelpTftp/Ftp_SourceDir
Configures the TFTP or FTP directory for Help files, in one of the following formats: a.b.c.d:/| peer:/ [<dir>]. The path can use 0–256 characters. The following example paths illustrate the correct format:
  • 192.0.2.1:/Help
  • 192.0.2.1:/
DefaultDisplayRows
Configures the number of rows each page displays. The default is 30.
LastChange
Shows the last web-browser initiated configuration change.
NumHits
Shows the number of hits to the web server.
NumAccessChecks
Shows the number of access checks performed by the web server.
NumAccessBlocks
Shows the number of access attempts blocked by the web server.
LastHostAccessBlockedAddressType
Shows the address type, either IPv4 or IPv6, of the last host access blocked by the web server.
Shows the IP address of the last host access blocked by the web server.
NumRxErrors
Shows the number of receive errors the web server encounters.
NumTxErrors
Shows the number of transmit errors the web server encounters.
NumSetRequest
Shows the number of set-requests sent to the web server.
