Use this procedure to create a MAC access list or add a MAC address to the existing MAC access list.
- Select FHS.
- Select the MAC Access List tab.
- Select Insert.
- Configure the parameters for the MAC access list.
- Select Insert.
MAC Access List Field Descriptions
Use the data in the following table to use the MAC Access List tab.
Name |
Description |
Name |
Specify a name to create a MAC access list. |
Mac |
Specify the MAC address to add to the MAC access list, in (xx:xx:xx:xx:xx:xx) format. |
AccessType |
Specify allow or deny. By default, the access type is allow. |
