Configure ACE IPv6 next header entries to have the filter look for specific next headers.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select IPv6.
  8. Select the Next Hdr tab.
  9. Select Insert.
  10. In Oper, select the operation type.
  11. In NextHdr, select the next header type.
  12. Select Insert.
Next Header Field Descriptions
Use the data in the following table to use the Next Hdr tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq parameter specifies an operator for an “equal to” field match condition.
NextHdr
Specifies the next header of the IPv6 header. Specifies hop-by-hop, tcp, udp, routing, fragment, ipsecESP, ipsecAH, icmpv6, noNxtHdr, or undefined.
