Enable RIP globally.
Configure a route policy.
Configure a redistribute entry to announce routes of a certain source protocol type into the RIPng domain, for example, static, RIP, or direct. Use a route policy to control the redistribution of routes.
- In the navigation pane, expand Configuration > IPv6.
- Select IPv6 RIPng.
- Select the Redistribute tab.
- Double-click the value in the Enable column that corresponds with the source protocol type you want to enable or disable.
- Select enable or disable.
- Select Apply.
Redistribute Field Descriptions
Use the data in the following table to use the Redistribute tab.
Name |
Description |
DstVrfiId |
Specifies the destination VRF ID used in the redistribution. |
Protocol |
Specifies the dynamic routing protocol that receives the external routing information. |
SrcVrfId |
Specifies the source VRF ID used in the redistribution. |
RouteSource |
Specifies the route source protocol for the redistribution entry. |
Enable |
Enables (or disables) a RIPng redistribute entry for a specified source type. |
