Use this procedure to view Layer 2 IP traceroute results.
- Select L2Ping/L2Trace Route.
- Select the L2 IP Traceroute tab.
- To view the Layer 2 IP traceroute results, highlight an entry, and then select Result.
L2 IP Traceroute Result Field Descriptions
Use the data in the following table to use the L2 IP Traceoute Result tab.
Name |
Description |
IpAddrType |
Specifies the address type of destination IP address. |
IpAddr |
Specifies the destination IP address. |
SendOrder |
Denotes the order that sessions are sent. It is an index to distinguish among multiple L2Trace sessions. It correlates to the number of paths found. This value is assigned sequentially from 1. |
Hop |
Specifies the number of Layer 2 hops away from L2Trace initiator. |
ReceiveOrder |
Specifies the order that sessions are sent. It is an index to distinguish among multiple L2Trace responses with the same Send Transaction Identifier field value. This value is assigned sequentially from 1, in the order that the Linktrace Initiator received the responses. |
Ttl |
Specifies the time-to-live (TTL) field value for a returned L2Trace response. |
VrfId |
Specifies the VRF ID. |
VlanId |
Specifies the VLAN found from Layer 3 lookup and used for transmission. |
DestMacAddress |
Indicates the target MAC address transmitted. |
PortNum |
Specifies either the value '0', or the port number of the port used for the l2trace. |
SeqNumber |
Specifies the transaction identifier/sequence number used in linktrace message packet. The default is 0. |
SrcMac |
Specifies the MAC address of the MP that responded to L2Trace request for this L2traceReply. |
HostName |
Specifies the host name of the replying node. |
LastSrcMac |
Specifies the MAC address of the node that forwarded the L2Trace to the responding node. |
LastHostName |
Specifies the host name of the node that forwarded the L2Trace to the responding node. |
Flag |
L2Trace result flag indicating status or error code:
