Use this task to configure the DHCP Client to obtain an IPv4 address for the Management Instance VLAN interface or Out-of-Band interface.
The following example configures the DHCP Client to cycle IPv4 requests for the management OOB interface, and then the In-Band management VLAN interface; priority is given to the OOB interface. The system cycles attempts until one management interface receives an IP address from the DHCP server:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt dhcp-client cycle
The following table defines parameters for the mgmt dhcp-client command.
Variable |
Value |
cycle Note:
Exception: not supported on 5320 Series |
DHCP Client cycles IP requests for in-band VLAN and Out-of-Band management interfaces. |
oob Note:
DHCP Client requests an IP address for the Out-of-Band management interface. |
vlan |
DHCP Client requests an IP address for the VLAN management interface. |
