Enables you to debug the configuration file during loading configuration at system boot up. The default is disabled. You do not have to restart the switch after you enable debug-config, unless you want to immediately debug the configuration. After you enable debug-config and save the configuration, the debug output either displays on the console or logs to an output file the next time the switch reboots.
The options are:
  • debug-config [console]—Displays the line-by-line configuration file processing and result of the execution on the console while the device loads the configuration file.
  • debug-config [file]— Logs the line-by-line configuration file processing and result of the execution to the debug file while the device loads the configuration file. The system logs the debug config output to /intflash/debugconfig_primary.txt for the primary configuration file. The system logs the debug config output to /intflash/debugconfig_backup.txt for the backup configuration, if the backup configuration file loads.
    enable
    configure terminal
  2. Enable debugging of the configuration file:
    boot config flags debug-config [console] | [file]
  3. Save the changed configuration.
