View Ping Results
View ping results to view performance-related data.
![Note](images/note.png)
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see Fabric Engine Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Select Ping/Trace Route.
- Select the Ping Control tab.
- Select a ping test entry.
- Select Ping Result.
Ping Result Field Descriptions
Use the data in the following table to use the Ping Result tab.
Name |
Description |
OwnerIndex |
Specifies the ping test owner. |
TestName |
Specifies the test name. |
OperStatus |
Indicates the operational status of the test. The default is disabled. |
IpTargetAddressType |
Specifies the IP address type of the target. The default is unknown. |
IpTargetAddress |
Specifies the IP address of the target. |
MinRtt |
Specifies the minimum ping round-trip-time (RTT) received. A value of 0 means that no RTT is received. |
MaxRtt |
Specifies the maximum ping RTT received. A value of 0 means that no RTT is received. |
AverageRtt |
Specifies the current average ping RTT. |
ProbeResponses |
Specifies the number of responses to probes. |
SentProbes |
Specifies the number of sent probes. |
RttSumOfSquares |
Specifies the sum of squares of RTT for all probes received. |
LastGoodProbe |
Specifies the date and time when the last response is received for a probe. |
