Use the following procedure to remove specific IS-IS ports and MLT interfaces when you get the error IS-IS SPBM interfaces have been configured. Please delete these interfaces.
This procedure removes existing IS-IS ports and MLT interfaces. You can choose which port and MLT interfaces need to be removed. This command does not alter the other SPBM or IS-IS configurations.
You must enable SPBM before running the SPBM script.
    enable
    configure terminal
  2. Run the script:
    run spbm interface clean
    If the script causes a configuration conflict or cannot execute a command, an error message displays and the script stops.
Run the spbm interface clean script:
Switch:1(config)# run spbm interface clean
*** This script will guide you through deleting the           ***
*** IS-IS SPBM interfaces. 		                                ***
*** The values in [] are the default values.                  ***
*** If you wish to terminate or exit this script              ***
*** enter ^C <control-C> at any prompt.                       ***
ISIS port interfaces to be deleted <a/b,c/d>[]:1/2,1/4,1/8
ISIS MLT interface <MLT ID LIST> []:1
IS-IS port 1/2 deleted
IS-IS port 1/4 deleted
IS-IS port 1/8 deleted
** 3 IS-IS port interfaces deleted **
MLT 1 deleted
** 1 IS-IS MLTs deleted **
