Delete a CLI User Name
You must use an account with read-write-all privileges to delete a user.
Use this task to delete a user name. You cannot delete default ro, rw, and rwa users.
Delete user name "smith":
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#no username smith The specified username will be deleted! Contiune (y/n) ? Y Switch:1(config)#show cli username smith Username does not exit
The following table defines parameters for the no username command.
 Variable  |
 Value  |
 WORD <1–20>  |
 Specifies the username to delete.  |
 enable  |
 Disables the username.  |
