Configure the required SPBM and IS-IS infrastructure, which includes creating the SPBM B-VLANs.
Associate a T-UNI LACP MLT with a VLAN before mapping the LACP MLT to a T-UNI I-SID.
Caution
In the case of T-UNI LACP SMLT, before you configure SMLT on switch peers, ensure that the T-UNI LACP MLT on each peer is always associated with a VLAN, even if it is the default VLAN, and that it is added to a T-UNI I-SID. Otherwise, traffic is not forwarded on the T-UNI LACP MLT.
Use this procedure to configure a Transparent Port UNI or ELAN Transparent service.
You can configure Transparent Port UNI when either of the following apply:
You want all tagged and untagged traffic on a port to be classified into the same broadcast domain.
You want to offer a transparent provider solution.
If you configure a T-UNI to terminate on a port or MLT on a switch in a vIST switch cluster, you must also configure the T-UNI I-SID on the other switch of the vIST switch cluster. You must configure the T-UNI I-SID on both switches of a vIST pair. You do not need to assign an actual port or MLT to the T-UNI on the second switch.
Configure a Transparent Port UNI I-SID (ELAN-Transparent based service).
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#i-sid 3 elan-transparent Switch:1(elan-tp:3)#port 1/25 Adding Ports to Transparent UNI i-sid removes it from all VLANS. Do you wish to continue (y/n) ? y Switch:1(elan-tp:3)#mlt 1 Adding MLTs to Transparent UNI i-sid removes it from all VLANS. Do you wish to continue (y/n) ? y
Verify Transparent Port UNI or ELAN-Transparent based service configuration.
Switch:1(config)#show i-sid 3
Isid Info
ISID ISID PORT MLT ORIGIN ISID
ID TYPE VLANID INTERFACES INTERFACES NAME
3 ELAN_TR N/A - - CONFIG ISID-3
Variable definitions
The following table defines parameters for the i-sid command.
When SPB is enabled, I-SID IDs 16000000 (0xF42400) and greater, up to 16,777,215 (0xFFFFFF), are reserved for dynamic i-sid allocation and used to support IP Multicast traffic over SPB and other advanced Fabric services.
Variable |
Value |
i-sid <1–16777215> elan-transparent |
Creates an ELAN-Transparent based service. The service interface identifier (I-SID) range is 1 to 16777215. |
port {sub-port]][,...][slot/all][all]} |
Add ports to the ELAN-Transparent based service. |
mlt<1–512> |
Add MLTs to the ELAN-Transparent based service. The MLT range is 1 to 512. |
