Configure the MLD Robustness
The robustness value allows the tuning for the expected packet loss on a link. If a link expects packet loss, increase the robustness variable value.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Configure the MLD robustness:
    ipv6 mld robust-value <2-255>
The following table describes the variables for the ipv6 mld robust-value command.
Variable Value
<2–255>
Specifies a numerical value for MLD snooping robustness.
