Use the following procedure to view the Intermediate-System-to-Intermediate-System (IS-IS) interface control packets.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select Stats.
  3. Select the Interface Control Packets tab.
Interface Control Packets Field Descriptions
Use the data in the following table to use the Interface Control Packets tab.
Name
Description
Index
Shows a unique value identifying the Intermediate-System-to-Intermediate-System (IS-IS) interface.
Direction
Indicates whether the switch is sending or receiving the PDUs.
Hello
Indicates the number of IS-IS Hello frames seen in this direction at this level.
LSP
Indicates the number of IS-IS LSP frames seen in this direction at this level.
CSNP
Indicates the number of IS-IS Complete Sequence Number Packets (CSNP) frames seen in this direction at this level.
PSNP
Indicates the number of IS-IS Partial Sequence Number Packets (PSNP) frames seen in this direction at this level.
