The following table defines parameters for the ip address command.
| Variable | Value |
<A.B.C.D/X>|<A.B.C.D> <A.B.C.D> |
Specifies the IP address and subnet mask in the format A.B.C.D/X or A.B.C.D A.B.C.D. |
multi-area-virtual-link |
Specifies that the source IP address is used for a Mulit-area virtual NNI link. |
| <home | remote> |
Specifies the transport area for the Multi-area virtual NNI link. Note:
If you configure the loopback interface for the virtual NNI link in the home area, you must configure the IS-IS logical interface for the virtual NNI link in the remote area, and vice versa. |
name WORD<0-64> |
Specifies a name associated with the IP address. Note:
If you do not assign a name
when you configure virtual NNI links for Multi-Area boundary
nodes for 5720 Series, 7520 Series, and 7720 Series, the system autogenerates the name and
displays the name as |
The following tables define parameters for the logical-intf isis command.
| Variable | Value |
<1-255> |
Specifies the index number that uniquely identifies this logical interface. |
| dest-ip <A.B.C.D> |
Specifies the destination IP address of the Multi-area virtual NNI link. Note:
This IP address is the loopback source IP address. |
Specifies that the logical interface is used for a Multi-area virtual NNI link. |
name WORD<1-64> |
Specifies a name associated with the logical interface. Note:
The following tables define parameters for the isis command.
| Variable | Value |
remote |
Specifies the remote area as the IS-IS interface. If the loopback interface for the virtual NNI link is configured in the remote area, omit this parameter. |
enable |
Enables the IS-IS interface for the virtual NNI link. The default is disabled. |
| spbm <1-100> |
Specifies the SPBM instance on the IS-IS interface. |
