Manually configure the port speed.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the speed for one or more ports:
    speed {10|100|1000|10000|2500|25000|5000}
    or
    speed port {sub-port]][,...][slot/all][all]} {10|100|1000|10000|2500|25000|5000}
The following table defines parameters for the speed command.
Variable
Value
Specifies the port or ports that you want to configure.
10
Configures the port speed to 10 Mbps.
100
Configures the port speed to 100 Mbps.
1000
Configures the port speed to 1 Gbps.
10000
Configures the port speed to 10 Gbps.
2500
Configures the port speed to 2.5 Gbps.
25000
Configures the port speed to 25 Gbps.
5000
Configures the port speed to 5 Gbps.
