Use the following procedure to configure the dead-peer detection (DPD) timeout for the IKE Phase 1 policy.
Dead Peer Detection (DPD) timeout is the interval for which the system sends messages to a peer to confirm its availability.
    enable
    configure terminal
  2. Configure the DPD timeout:
    ike policy WORD<1–32> dpd-timeout <1–4294967295>
Variable Definition
The following table defines parameters for the ike policy WORD<1–32> dpd-timeout command.
Variable
Value
policy WORD<1–32>
Specifies the name of the IKE Phase 1 policy.
Specifies the dead peer detection timeout in seconds for the IKE Phase 1 policy. The default is 300 seconds. To set this option to the default value, use the default operator with the command: default ike policy WORD<1–32> dpd-timeout
