Perform this procedure to migrate a new routing VLAN with a new IP address or a new loopback IP address under a different VRF to the Segmented Management Instance. Alternatively, you can also use the convert command.
Important
Choose a VLAN that does not have an IP interface on it. The upgrade process removes the IP configuration and network connectivity will be impacted.
You cannot migrate interfaces used for routing purposes, for example, where you configure Layer 3 routing protocols.
This command does not apply to the OOB or mgmtEthernet interface. Releases that support this migration procedure automatically move the IP address on the mgmtEthernet interface from the routing stack to the Segmented Management Instance.
- Select Mgmt Instance.
- Select Mgmt.
- Select the Migrate tab.
- Select Insert.
- Select the instance type, either clip or vlan.
- Specify the existing VLAN or loopback ID.
- Select Insert.
Migrate Field Descriptions
Use the data in the following table to use the Migrate tab.
Name |
Description |
InstanceId |
Specifies the interface instance to migrate. |
InterfaceIndex |
Shows the interface index of the identified interface. |
InterfaceType |
Shows the interface type. |
Description |
Shows the interface description. |
VlanId |
Specifies the VLAN ID for a port-based VLAN. |
LoopbackId |
Specifies the loopback ID. |
VrfName |
Shows the VRF associated with the loopback interface. |
IpAddress |
Shows the IPv4 address to migrate. |
IpMask |
Shows the subnet mask for the IPv4 address. |
Ipv6Address |
Shows the IPv6 address to migrate. |
Ipv6PrefixLength |
Shows the prefix length for the IPv6 address. |
