You can disable EAPoL authentication for specific Fabric Attach (FA) client types.
By default, authentication is required before the connection is authorized.
The following table defines parameters for the auto-sense commands related to EAPoL authentication for Fabric Attach (FA).
Variable |
Value |
{authorized | auto} |
Configures the EAPoL authentication requirement for the specific client type. Choose from the following options:
By default, authentication is required before the connection is authorized. |
