The following table defines parameters for the ip dhcp-server command.
Variable | Definition |
ha-peer {A.B.C.D} |
Specifies the IPv4 address of the redundant peer switch in a High Availability (HA) pair. |
ha-role {primary | standby} |
Assigns the High Availability (HA) role of this switch. Within an HA pair, you must have one primary server and one standby server that do the following:
Note: Assigning roles
is optional. By default, the switch with the lower IP address is
primary.
