Configure Rapid Spanning Tree Protocol (RSTP) to reduce the recovery time after a network breakdown.
    enable
    configure terminal
  2. Configure RSTP:
    spanning-tree rstp [forward-time <400–3000>] [group-stp enable] [hello-time <100–1000>] [max-age <600–4000>] [pathcost-type <bits16|bits32>] [priority <0–61440>] [tx-holdcount <1–10>] [version <rstp|stp-compatible>]
Configure RSTP:
 Switch:1(config)# spanning-tree rstp forward-time 1000 hello-time 200 max-age 4000 pathcost-type bits16 priority 4096 tx-holdcount 10 version rstp group-stp enable
Use the data in the following table to use the spanning-tree rstp command.
Variable
Value
forward-time <400-3000>
Configures the RSTP forward delay for the bridge in hundredths of a second.
group-stp enable
Enables or disables RSTP for a specific STG. Enter the no form of the command to disable RSTP for the STG (no spanning-tree rstp group-stp enable).
hello-time <100-1000>
Assigns the RSTP hello time delay for the bridge in hundredths of a second.
max-age <600-4000>
Assigns the RSTP maximum age time for the bridge in hundredths of a second.
pathcost-type {bits16|bits32}
Assigns the RSTP default pathcost version. The default is 32 bits.
priority <0-61440>
Assigns the RSTP bridge priority.
tx-holdcount <1-10>
Assigns the RSTP transmit hold count from 1 to 10. The default value is 6.
version {rstp/stp-compatible}
Sets the version to RSTP or STP compatible.
