BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
- Select IPv6 BFD.
- Select Insert.
- In Interface, select either Port or Vlan, and then select an interface.
- In NextHop, type the IPv6 address of the next hop of the BFD session.
- Optional: In VrfId, type the ID of the VRF associated with the BFD session.
- Select Insert.
IPv6 BFD Static Route Field Descriptions
Use the data in the following table to use the Static Route tab.
| Name | Description |
Interface |
Specifies either a port or VLAN interface. |
NextHop |
Specifies the IPv4 address of the next hop of the BFD session. |
VrfId |
Specifies the ID of the VRF associated with the BFD session. |
VrfName |
Specifies the name of the VRF associated with the BFD session. |
