DHCP Relay Configuration
Complete the following tasks to configure DHCP Relay on the switch.
Table 1. DHCP Relay Configuration
Steps Task Description
1
Configure DHCP forwarding path entries as part of the DHCP Relay global configuration.
2
Configure DHCP option 82
(Optional). Enable the circuit ID to encode an agent-local identifier of the circuit from which a DHCP client-to-server packet is received.
3
Enable DHCP Relay on a port or VLAN interface.
