You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IGMP.
  3. Select the Multicast Router Discovery tab.
  4. To edit the current configuration, double-click the value, make the change, and then select Apply.
Multicast Router Discovery Field Descriptions
Use the data in the following table to use the Multicast Router Discovery tab.
Name
Description
Interface
Shows the interface where IGMP is enabled.
MrdiscEnable
Enables (true) or disables (false) the router interface to listen for multicast router discovery messages to determine where to send multicast source data and IGMPv2 reports. If you enable snoop, you automatically enable multicast router discovery.
DiscoveredRouterPorts
Lists ports that the Multicast Router Discovery (MRDISC) protocol discovers.
Important:
The switch does not support the MRDISC protocol on brouter ports.
MaxAdvertiseInterval
Shows the maximum time allowed between sending router advertisements from the interface, in seconds. The range is from 2–180 seconds. The default is 20 seconds.
MinAdvertiseInterval
Shows the minimum time allowed between sending unsolicited router advertisements from the interface, in seconds. This value must be more than 3 seconds but no greater than the value assigned to the MaxAdvertiseInterval value.
MaxInitialAdvertiseInterval
Configures the maximum number (in seconds) of multicast advertisement intervals that you can configure on the switch.
MaxInitialAdvertisements
Configures the maximum number of initial multicast advertisements that you can configure on the switch.
NeighborDeadInterval
Shows the time interval (in seconds) before the router interface drops traffic after a user leaves the multicast group.
