Configure a new password for a user if the password has expired or locked. Only the administrator can configure a password for a user.
  • You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
    enable
    configure terminal
  2. Create accounts on the switch for different access levels:
    password set–password user-name WORD<1–255>
  3. Save the configuration:
    save config
    This command saves the configuration using the file name configured as the primary configuration. Use the command show boot config choice to view the current primary and backup configuration file names.
Configure a password for jsmith:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#password set–password user-name jsmith
Enter the New password : *********************
Switch:1(config)#Password modified for user jsmith
Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password set-password command.
Variable
Value
Specifies the user for which to configure the password.
