Perform this procedure to view the IGMP interface table.
If an interface does not use an IP address, the system does not display it in the IGMP table. One exception is an IGMP snooping interface, which does not require an interface IP address.
If an interface uses an IP address, but neither IGMP snoop or PIM is enabled, the system displays the interface as inactive in the Status field.
View IGMP interfaces:
Switch:1#show ip igmp interface vrf l3vsn-100
Igmp Interface - VRF l3vsn-100
QUERY OPER QUERY WRONG LASTMEM SCOPE
IF INTVL STATUS VERS. VERS QUERIER MAXRSPT QUERY JOINS ROBUST QUERY MODE L2ISID ISID
V10 125 inact 2 2 0.0.0.0 100 0 0 2 10 routed-spb 0 100
The following table defines parameters for the show ip igmp interface command.
Variable |
Value |
gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
If you do not specify a slot and port, the command output includes all IGMP interfaces. |
vlan <1-4059> |
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. If you do not specify a VLAN ID, the command output includes all IGMP interfaces. |
vrf WORD <1–16> |
Optionally, identifies the VRF name. If you do not specify a VRF name, the results display information for the Global Router. If you specify a VRF name, the results display information only for the VRF you specify. |
vrfids WORD <0–512> |
Optionally, identifies the VRF ID. If you do not specify a range of VRF IDs, the results display information for the Global Router. If you specify a VRF ID or range of VRF IDs, the results display information only for the VRF you specify. |
