Use the following commands to check TLV information.
The LSPs carry I-SID information and information about where IP multicast stream senders and receivers exist using the following TLVs :
show isis lsdb tlv <1–236> [sub-tlv <1–3>][detail] [home|remote]
show isis lsdb lspid <xxxx.xxxx.xxxx.xx-xx> tlv <1–236> [sub-tlv <1–3>] [detail] [home|remote]
Display TLV information for Layer 2 or Layer 3 VSNs:
Switch:1# show isis lsdb tlv 185 detail ================================================================================ ISIS LSDB (DETAIL) ================================================================================ -------------------------------------------------------------------------------- Level-1LspID: 000c.f803.83df.00-00 SeqNum: 0x000001ae Lifetime: 898 Chksum: 0xcebe PDU Length: 522 Host_name: Switch Attributes: IS-Type 1 TLV:185 SPBM IPVPN : VSN ISID:5010 BVID :10 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.1 Data ISID : 16300001 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.3 Data ISID : 16300003 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.5 Data ISID : 16300005 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.7 Data ISID : 16300007 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.9 Data ISID : 16300009 TX : 1 VSN ISID:5010 BVID :20 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.2 Data ISID : 16300002 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.4 Data ISID : 16300004 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.6 Data ISID : 16300006 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.8 Data ISID : 16300008 TX : 1 Metric:0 IP Source Address: 192.0.2.1 Group Address : 233.252.0.10 Data ISID : 16300010 TX : 1 Switch:1# show isis lsdb lspid 000c.f803.83df.00-05 tlv 144 detail ================================================================================ ISIS LSDB (DETAIL) ================================================================================ -------------------------------------------------------------------------------- Level-1 LspID: 000c.f803.83df.00-00 SeqNum: 0x00000477 Lifetime: 903 Chksum: 0x200b PDU Length: 522 Host_name: Switch Attributes: IS-Type 1 Instance: 0 Metric: 0 B-MAC: 03-00-00-00-00-00 BVID:10 Number of ISID's:5 16000001(Tx),16000003(Tx),16000005(Tx),16000007 (Tx),16000009(Tx) Instance: 0 Metric: 0 B-MAC: 03-00-00-00-00-00 BVID:20 Number of ISID's:5 16000002(Tx),16000004(Tx),16000006(Tx),16000008(Tx),16000010(Tx)
Display TLV information for IP Multicast over Fabric Connect within the GRT:
Switch:1# show isis lsdb tlv 186 detail ================================================================================ ISIS LSDB (DETAIL) ================================================================================ -------------------------------------------------------------------------------- Level-1 LspID: 000c.f803.83df.00-06 SeqNum: 0x000002eb Lifetime: 1113 Chksum: 0x7e3b PDU Length: 556 Host_name: Switch Attributes: IS-Type 1 TLV:186 SPBM IP Multicast: GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.1 Data ISID : 16300012 BVID : 20 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.2 Data ISID : 16300013 BVID : 10 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.3 Data ISID : 16300014 BVID : 20 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.4 Data ISID : 16300015 BVID : 10 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.5 Data ISID : 16300016 BVID : 20 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.6 Data ISID : 16300017 BVID : 10 TX : 1 Route Type : Internal GRT ISID Metric:0 IP Source Address: 192.2.0.10 Group Address : 233.252.0.7 Data ISID : 16300018 BVID : 20 TX : 1 Route Type : Internal
