Enable RADIUS-SNMP Accounting
  • You must configure a RADIUS server before you can enable RADIUS-SNMP accounting.
Enable Remote Access Dial-in User Services (RADIUS) Simple Network Managing Protocol (SNMP) accounting globally. Use SNMP to remotely collect management data. An SNMP agent is a software process that monitors the UDP port 161 for SNMP messages. Each SNMP message sent to the agent contains a list of management objects.
    enable
    configure terminal
  2. Enable RADIUS Simple Network Management Protocol (SNMP) accounting globally:
    radius-snmp acct-enable
  3. Set a timer to send a stop accounting message for RADIUS Simple Network Management Protocol (SNMP):
    radius-snmp abort-session-timer <30–65535>
  4. Set the timer for re-authentication of the SNMP session:
    radius-snmp re-auth-timer <30–65535>
  5. Specify the user name for SNMP access:
    radius-snmp user WORD <0–20>
 Switch:1> enable
 Switch:1# configure terminal
 Switch:1(config)# radius-snmp acct-enable
 Switch:1(config)# radius-snmp abort-session-timer 30
The following table defines parameters for the radius-snmp command.
Variable
Value
acct-enable
Enables RADIUS accounting globally. You cannot enable RADIUS accounting before you configure a valid server. The system disables RADIUS accounting by default. The default is false. Use the no option to disable RADIUS accounting globally: no radius-snmp acct-enable
Set the timer, in seconds, to send a stop accounting message. The default is 180.
Sets timer for re-authentication of the SNMP session. The timer value ranges from 30 to 65535 seconds. The default is 180.
user WORD <0–20>
Specifies the user name for SNMP access. WORD <0–20> specifies the user name in a range of 0 to 20 characters. The default is snmp_user.
