The following table defines parameters for the ipv6 area command.
| Variable | Value |
| {A.B.C.D} | Specifies the area address. |
The following table defines parameters for the interface loopback command.
| Variable | Value |
| <1-256> | Specifies the interface ID. |
The following table defines parameters for the ipv6 interface address command.
| Variable | Value |
| WORD<0-255> |
Specifies the IPv6 address for the loopback interface. |
The following table defines parameters for the ipv6 ospf command.
| Variable | Value |
| <1-256> |
Specifies the interface ID for this IPv6 ospf interface. |
| area {A.B.C.D} |
Specifies the IPv6 OSPF area, typically formatted as an IP address. Enter the address in the {A.B.C.D} portion. |
