Enable IPFIX Globally
Use the following procedure to enable IPFIX globally. IPFIX provides the ability to monitor IPv4 traffic flows.
The default global state is disabled.
Enable IPFIX globally:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix enable
Disable IPFIX globally:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#no ip ipfix enable By disabling IPFIX globally, all the processes and traffic sent to collector(s) will be stopped.Do you agree (y/n) ? y
