View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
View Layer 3 VSN information on a DvR Controller:
Switch:1#show dvr l3vsn ==================================================================== DVR L3VSN ==================================================================== VRF ID L3VSN ISID VRF NAME INJECT-DEFAULT-ROUTE-DISABLE -------------------------------------------------------------------- 1 55500 vrf600 Disabled 2 55501 vrf601 Disabled 3 55502 vrf602 Disabled 4 55503 vrf603 Disabled 4 out of 4 Total Num of DVR L3VSN displayed ---------------------------------------------------------------------
View Layer 3 VSN information on a DvR Leaf node:
Switch2:1#show dvr l3vsn ==================================================================== DVR L3VSN ==================================================================== VRF ID L3VSN ISID VRF NAME -------------------------------------------------------------------- 1 55500 vrf600 2 55501 vrf601 3 55502 vrf602 3 out of 3 Total Num of DVR L3VSN displayed ---------------------------------------------------------------------
Variable definitions
Use the data in the following table to use the show dvr l3vsn command.
Variable |
Value |
l3isid <0-16777215> |
Specifies the Layer 3 VSN I-SID. The range is 0 to 16777215. |
vrf WORD<1-16> |
Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID. |
vrfids WORD<0-512> |
Specifies the VRF ID of the VRF. |
