Use this task to view IP address statistics for a Segmented Management Instance.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Mgmt Instance.
  3. Select Stats.
  4. Select the IP tab.
  5. To clear IP statistics, select Clear Stats.
  6. To clear IP counters, select Clear Counters.
IP Field Descriptions
Use the data in the following table to use the IP tab.
Name
Description
InReceives
Shows the inbound packet statistics.
InHdrErrors
Shows the inbound packets with header errors statistics.
InAddrErrors
Shows the inbound packets with address errors statistics.
InUnknownProtos
Shows the inbound packets with unknown protocols statistics.
InDiscards
Shows the inbound packets discarded statistics.
InDelivers
Shows the inbound packets delivered statistics.
OutRequests
Shows the outbound packet requests statistics.
OutDiscards
Shows the outbound packets discarded statistics.
OutNotRoutes
Shows the outbound packets with no routes statistics.
ForwDatagrams
Shows the forwarded datagram packets statistics.
ReasmTimeout
Shows the packet reassembly timeouts statistics.
ReasmReqds
Shows the packet reassembly requests statistics.
ReasmOKs
Shows the successfully reassembled packets statistics.
ReasmFails
Shows the failed reassembled packets statistics.
FragOKs
Shows the successfully fragmented packets statistics.
FragFails
Shows the failed fragmented packets statistics.
FragCreates
Shows the fragments created statistics.
