Use the following procedure to display status information about the OVSDB controller.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select OSVDB.
  3. Select the Status tab.
Status Field Descriptions
Use the data in the following table to use the Status tab.
Name
Description
IpAddress
Displays the IP address of a controller.
Protocol
Displays the communications protocol of a controller as TCP or SSL.
Port
Displays the communications port for the controller. Value range of 1 to 65535.
Source
Displays the source of the controller as learned or configured.
OperStatus
Displays the operational status of the controller.
