Perform this procedure to view the remote Intermediate-System-to-Intermediate-System (IS-IS) system statistics.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select Stats Remote.
  3. Select the System Stats tab.
System Stats Field Descriptions
Use the data in the following table to use the System Stats tab.
Name
Description
CorrLSPs
Indicates the number of corrupted in-memory link-state packets (LSPs) detected. LSPs received from the wire with a bad checksum are silently dropped and not counted.
AuthFails
Indicates the number of authentication key failures recognized by this Intermediate System.
LSPDbaseOloads
Indicates the number of times the LSP database has become overloaded.
ManAddrDropFromAreas
Indicates the number of times a manual address has been dropped from the area.
AttmptToExMaxSeqNums
Indicates the number of times the IS has attempted to exceed the maximum sequence number.
SeqNumSkips
Indicates the number of times a sequence number skip has occurred.
OwnLSPPurges
Indicates the number of times a zero-aged copy of the system's own LSP is received from some other node.
IDFieldLenMismatches
Indicates the number of times a PDU is received with a different value for ID field length to that of the receiving system.
PartChanges
Indicates partition changes.
AbsoluteValue
Displays the counter value.
Cumulative
Displays the total value since you opened the Stats tab.
Average/sec
Displays the average value for each second.
Minimum/sec
Displays the minimum value for each second.
Maximum/sec
Displays the maximum value for each second.
LastVal/sec
Displays the last value for each second.
