View the IPv4 address bindings that IP Source Guard (IPSG) allows.
  1. To enter User EXEC mode, log on to the switch.
  2. View the allowed IPv4 address bindings for a specific interface:
    show ip source binding [interface gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]|[vlan <1-4059>]|[vrf WORD<1-16>]|[vrfids WORD<0-512>]
  3. View the allowed IPv4 address bindings for a specific IP address:
    show ip source binding {A.B.C.D}
View the allowed IPv4 address bindings for the port 1/1.
Switch:1>show ip source binding interface gigabitEthernet 1/1
                                                   IPSG Source Table
PORT       IP              VLAN    VRF
NUM        ADDRESS         ID      NAME
1/1        192.0.2.1       200     GlobalRouter
All 1 out of 1 Total IP Source Guard entries displayed
View the IPv4 address bindings for a specific IP address.
Switch:1>show ip source binding 192.0.2.1
                                                   IPSG Source Table
PORT       IP              VLAN    VRF
NUM        ADDRESS         ID      NAME
The following table defines parameters for the show ip source binding command.
Variable
Value
{A.B.C.D}
Identifies the IPv4 address.
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
vlan <1-4059>
Specifies the VLAN ID of the VLAN for which to view IPv4 address bindings.
vrf WORD<1-16>
Specifies the VRF name of the VRF for which to view the IPv4 address bindings.
vrfids WORD<0-512>
Specifies the VRF ID of the VRF for which to view IPv4 address bindings.
