Use this procedure to configure a management I-SID on a Fabric Attach (FA)-enabled port or MLT.
To configure an FA management I-SID for Auto-sense-enabled ports, see Configure a Management I-SID for Auto-sense Fabric Attach Proxy Switches.
Ensure that the port or MLT is enabled for FA.
This command applies to all traffic sent or received on a port or MLT, carrying the VLAN ID specified using the c-vid parameter. This parameter is optional.
Depending on whether the c-vid parameter is specified or not, the behavior is as follows:
  • If you specify the c-vid parameter, the FA Server transmits this VLAN ID as the management VLAN in the FA Element TLV. A client or proxy receiving this TLV uses this VLAN-ID for management traffic on the FA Server uplink.
  • If you do not specify the c-vid parameter, the FA Server transmits a management VLAN with a VLAN ID value of 4095 in the FA Element TLV. A client or proxy receiving this TLV uses untagged traffic for network management on the FA Server uplink.
An FA management I-SID can have a platform VLAN associated with it. For Layer 3 support on the management I-SID, you must create a platform VLAN by port and associate the platform VLAN with the management I-SID. The C-VID can be of the same value or of a different value than that of the platform VLAN.
If the management I-SID matches one of the FA Switched UNI (ELAN) I-SIDs (as displayed by the command show i-sid elan), then the platform VLAN is automatically associated with the FA-enabled interface (port or MLT).
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface mlt <1-512>
  2. Configure the FA management I-SID:
    fa management i-sid <1-16777215> c-vid <1-4094>
    Important
    Important
    If you do not specify a C-VID value, the port or MLT is untagged.
  3. Verify configuration of FA management on the port or MLT, using the following commands:
    • show i-sid <1-16777215>
    • show interfaces gigabitEthernet i-sid [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
    • show mlt i-sid [<1–512>]
Configure FA management on port 1/2:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#interface gigabitethernet 1/2
Switch:1(config-if)#fa management i-sid 101 c-vid 101
Switch:1(config-if)#show i-sid 101
                                         Isid Info
ISID     ISID                 PORT            MLT             ORIGIN       ISID
ID       TYPE       VLANID    INTERFACES      INTERFACES                   NAME
101      ELAN        3          -               -             CONFIG      EXTRSERVER_101
The following example demonstrates the Origin as "auto-sense".
Switch:1(config-if)#show i-sid 500
                                           Isid Info
101      ELAN        -        c300:1/45        -              AUTO-SENSE   ISID_500
Switch:1(config-if)#show interfaces gigabitEthernet i-sid
                           PORT Isid Info
                ISID                ISID               ISID                  MAC
PORTNUM IFINDEX ID    VLANID C-VID  TYPE   ORIGIN      NAME            BPDU  SUNI
1/2     193     101   3      101    ELAN   MANAGEMENT  EXTRSERVER_101
1 out of 1 Total Num of i-sid endpoints displayed
Configure FA management on MLT 10.
Switch:1>enable
Switch:1(config)#interface mlt 10
Switch:1(config-mlt)#fa management i-sid 101
Verify configuration of FA management on the MLT. Because the C-VID is not specified, the MLT displays as untagged.
Switch:1(config-mlt)#show i-sid 101
                                                       Isid Info
101      ELAN        3          -              u:10           CONFIG     EXTRSERVER_101
In the following example, for Layer 3 support, create a platform VLAN 3 and associate it with the management I-SID 101.
Switch:1(config-if)#vlan create 3 type port-mstprstp 0
Switch:1(config-if)#vlan i-sid 3 101
Switch:1(config)#show i-sid
                                                       Isid Info
15999999   ELAN     4048      -            -             C  ---  -  ---  -  -      Onboarding I-SID
16777001   ELAN     N/A       -            -             C  ---  -  ---  -  -      FAN-ISID
c: customer vid    u: untagged-traffic
All 2 out of 2 Total Num of i-sids displayed
ORIGIN Legend:
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense; R: multi-area redist
l: discover by local switch  r: discover by remote VIST switch
Switch:1(config-if)#show vlan i-sid
                                   Vlan I-SID
VLAN_ID    I-SID                I-SID NAME
1
2
3          101                  EXTRSERVER_101
33
999
Because the management I-SID matches one of the FA Switched UNI (ELAN) I-SIDs, the platform VLAN is automatically associated with the FA-enabled port 1/2.
                           PORT Isid Info
                ISID                ISID               ISID                  MAC
The following table defines parameters for the fa management command.
Variable
Value
i-sid<1-16777215>
Specifies the management I-SID.
<1-4094>
Specifies the customer VLAN ID.
Important:
