View SLPP Guard Status
View current SLPP Guard settings.
- Select SLPP.
- Select the SLPP Guard tab.
SLPP Guard Field Descriptions
Use the data in the following table to use the SLPP Guard tab.
| Name | Description |
| IfIndex | Specifies the port on which to configure SLPP Guard. |
| Enable | Enables (true) or disables (false) SLPP Guard for the port. The default is disabled. |
| Timeout | Specifies the time period, in seconds, for which SLPP Guard disables the port. After the timeout period expires, the switch re-enables the port. The timeout value can be 0 or a value ranging from 10 to 65535. With a value of 0, the port remains disabled until it is manually re-enabled. The default Timeout value is 60 seconds. |
| Status | Displays the SLPP Guard status for the port. |
| TimerCount | Indicates the time, in seconds, that elapses after SLPP Guard disables a port. When the TimerCount value equals the Timeout value, the switch re-enables the port. |
| GuardOrigin | Specifies the origin of SLPP Guard configuration on the port. The supported values are:
