View DvR Database Information
Ensure that DvR is enabled globally on the node.
View all DvR routes on a Controller or a Leaf node.
The Controller node displays all the IP subnet routes configured for that DvR domain. A Leaf node displays all IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. It also displays the Host Routes (ARPs) learned from other DvR enabled nodes.
View the DvR database on either a Controller or a Leaf node.
Switch:1#show dvr database ================================================================================================================================== DVR DATABASE ================================================================================================================================== NEXT L3VSN L2VSN OUTGOING SPB PREFIX DEST MASK HOP VRFID ISID ISID INTERFACE COST COST AGE AREA AREA-NAME ---------------------------------------------------------------------------------------------------------------------------------- 40.0.0.0 255.255.0.0 Ctrl-1:K:121 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.2 255.255.255.255 Ctrl-1:K:121 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.3 255.255.255.255 Ctrl-2:K:122 101 0 40400 MLT-1 10 1 0 day(s), 05:44:30 HOME area-49.0016 3 out of 3 Total Num of DVR Database entries displayed ----------------------------------------------------------------------------------------------------------------------------------
View the DvR database for a specific IPv4 address:
Switch:1#show dvr database ipv4 40.3.1.2 ================================================================================================================================== DVR DATABASE ================================================================================================================================== NEXT L3VSN L2VSN OUTGOING SPB PREFIX DEST MASK HOP VRFID ISID ISID INTERFACE COST COST AGE AREA AREA-NAME ---------------------------------------------------------------------------------------------------------------------------------- 40.3.1.2 255.255.255.255 Ctrl-1:K:121 0 0 40403 cpp 10 1 0 day(s), 05:50:03 HOME area-49.0016 1 out of 1225 Total Num of DVR Database entries displayed ----------------------------------------------------------------------------------------------------------------------------------
View DvR database entries for a specific L3 I-SID.
Switch:1#show dvr database l3isid 0 ================================================================================================================================================ DVR DATABASE ================================================================================================================================================ NEXT L3VSN L2VSN OUTGOING SPB PREFIX DEST MASK HOP VRFID ISID ISID INTERFACE COST COST AGE AREA AREA-NAME ------------------------------------------------------------------------------------------------------------------------------------------------ 40.0.0.0 255.255.0.0 Ctrl-1:K:121 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.2 255.255.255.255 Ctrl-1:K:121 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.3 255.255.255.255 Ctrl-2:K:122 0 0 40400 MLT-l 10 1 0 day(s), 05:44:30 HOME area-49.0016 3 out of 3 Total Num of DVR Database entries displayed ----------------------------------------------------------------------------------------------------------------------------------------------
View DvR database entries with next hop MAC address displayed instead of the system name:
Switch:1#show dvr database nh-as-mac ================================================================================================================================================= DVR DATABASE ================================================================================================================================================= NEXT L3VSN L2VSN OUTGOING SPB PREFIX DEST MASK HOP VRFID ISID ISID INTERFACE COST COST AGE AREA AREA-NAME ------------------------------------------------------------------------------------------------------------------------------------------------- 40.0.0.0 255.255.0.0 00:bb:00:00:81:21 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.2 255.255.255.255 00:bb:00:00:81:21 0 0 40400 cpp 10 1 0 day(s), 05:44:55 HOME area-49.0016 40.0.1.3 255.255.255.255 00:bb:00:00:81:22 0 0 40400 MLT-1 10 1 0 day(s), 05:44:30 HOME area-49.0016 3 out of 3 Total Num of DVR Database entries displayed ------------------------------------------------------------------------------------------------------------------------------------------------
Variable definitions
Use the data in the following table to use the show dvr database command.
Variable |
Value |
home |
Specifies the DvR database information for home instance. |
ipv4 {A.B.C.D} |
Specifies the IP address (IPv4) of the DvR database entry. |
l3isid <0-16777215> |
Specifies the Layer 3 I-SID of the DvR database entry. The range is 0 to 16777215. |
nh-as-mac |
Specifies the MAC address of the next hop node instead of the system name. |
remote |
Specifies the DvR database information for remote instance. |
vrf |
Specifies the VRF name of the DvR database entry. |
vrfids |
Specifies the VRF ID of the DvR database entry. The range is 0 to 512. |
