View EAPoL session statistics to manage network performance.
Use the clear-stats command to clear EAP/NEAP statistics.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the session statistics:
    show eapol session—stats interface [gigabitEthernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Switch:1#show eapol session-stats interface
                      Eap Authenticator Session Statistics
PORT  MAC                  SESSION   AUTHENTIC       SESSION               TERMINATE       USER
NUM                        ID        METHOD          TIME                  CAUSE           NAME
1/1   18:a9:05:b1:04:ce    cb000000  remote-server   0 day(s), 05:58:16    not-terminated  sachin
1/4   00:00:00:00:00:01    cb000002  remote-server   0 day(s), 05:48:01    not-terminated  000000000001
Use the data in the following table to use the show eapol session-stats interface command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
