Use this procedure to view the FA port statistics graphically.
Ensure that a switch port is selected in the Device Physical View tab.
  1. In the navigation pane, expand Graph > Port.
  2. Select the Fabric Attach tab.
    The FA port statistics are displayed.
  3. To view a graphical representation of the port statistics, select a row and select the appropriate icon on the top left-hand-side of the menu bar to draw a line chart, area chart, bar chart or a pie chart.
  4. Select Clear Counters to clear the existing counters, and fix a reference point in time to restart the counters.
  5. Select Export, to export the statistical data to a file.
  6. To fix a poll interval, select an appropriate value from the Poll Interval drop-down list.
Fabric Attach Field Descriptions
Use the data in the following table to use the Fabric Attach tab.
Name
Description
DiscElemReceived
Specifies the number of discovery elements received on a given port.
AsgnReceived
Specifies the number of remote I-SID-to-VLAN assignments received on a given port.
AsgnAccepted
Specifies the number of remote I-SID-to-VLAN assignments accepted on a given port.
AsgnRejected
Specifies the number of remote I-SID-to-VLAN assignments rejected on a given port.
AsgnExpired
Specifies the number of remote I-SID-to-VLAN assignments that expired on a given port.
AuthFailed
Indicates the number of received TLVs for which authentication was attempted and failed on the identified port.
DiscElemExpired
Specifies the number of discovery elements that expired on a given port.
DiscElemDeleted
Specifies the number of discovery elements that were deleted on a given port.
AsgnDeleted
Specifies the number of remote assignments that were deleted on a given port.
AsgnAuthFailed
Specifies the number of remote assignment authentications that failed on a given port.
