You can establish a threshold rate for receiving TC/TCN packets by configuring values for count and interval. If the threshold rate is exceeded, you receive a warning message.
Use the following procedure to configure values for tc-receive-alarm-threshold count and tc-receive-alarm-threshold interval.
    enable
    configure terminal
  2. Configure a value for count:
    spanning-tree tc-receive-alarm-threshold count <1-1000>
  3. Configure a value for interval:
    spanning-tree tc-receive-alarm-threshold interval <1-15>
Configure count and interval values:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#spanning-tree tc-receive-alarm-threshold count 3
Switch:1(config)#spanning-tree tc-receive-alarm-threshold interval 2
Display the alarm threshold configuration:
Switch:1#show spanning-tree tc-receive-alarm-threshold
             Spanning Tree TC/TCN Rx Alarm Threshold Configuration
Interval                : 2 minutes
Count                   : 3
Variable definitions
Use the data in the following table to use the tc-receive-alarm-threshold command.
Variable
Value
count <1-1000>
Specifies the number of packets used to establish the threshold rate. The default is 2.
interval <1-15>
Specifies the time interval (in minutes) used to establish the threshold rate. The default is 1.
